Cavitation with Nitrogen Liquid??
Old   July 17, 2014, 22:57
Default Cavitation with Nitrogen Liquid??
le hoang anh
lehoanganh07 is on a distinguished road
I want to do calculation for cavitation with Nitrogen liquid. But I dont know hoe to chose the material for each phase. As I did with water, in the material panel, I could chose water liquid and water vapor.
But for nitrogen liquid, I saw no option for that. Does any one know how to do cavitation with the nitrogen liquid?
lehoanganh07 is offline   Reply With Quote
Old   July 18, 2014, 04:25
khalil
thousand is on a distinguished road
hi
you can add your material to fluent
copy a fluid from fluent database
then in material panel change its name and properties with your favor name and properties then press "chang/create" button!
thousand is offline   Reply With Quote
Old   July 18, 2014, 04:57
le hoang anh
Thank for your reply!
But the state equation for liquid nitrogen is the equation for real gas, also it very sensitive to temperature, so the density can not be constant.
I tried to use NISF real gas in Fluent data base, but could not use for cavitation model
Is liquid Nitrogen a heat sink? vasava FLUENT 0 September 5, 2013 03:25
Liquid Nitrogen + Air Thanathat FLUENT 1 October 10, 2009 02:50
Evaporation of liquid nitrogen Mac CFX 1 October 3, 2008 06:47
evaporation on the surface of liquid nitrogen dodo FLUENT 0 March 3, 2008 04:37
Cavitation and Compressible Liquid JBS CFX 0 January 5, 2007 06:13
