how to add several initial velocity
Old   July 17, 2014, 09:52
Default how to add several initial velocity
ozy
oguzayin
ozy is on a distinguished road
Hi all,
Can someone explain me, how can i add several initial velocity values ? i mean that i have different velocity in inlet for different points.
Thanks in advance
Ozy
ozy is offline   Reply With Quote
Old   July 17, 2014, 20:27
blackmask will become famous soon enough
If you have an analytical expression for the inlet, use
DEFINE_PROFILE
otherwise use profile.
Are you doing boundary layer calculation? Not many people call inlet value as "initial" value, most of us regard it as "boundary" value.
blackmask is offline   Reply With Quote
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 19:31
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
