July 21, 2000, 10:03 |
UDF for VOF
I am working on a multi-phase problem. A tube is filled with water at t=0, then, an air bubble flows into the domain at the tube inlet. Due to surface tension, there is a curvature at the air/liquid interface. How to use UDF to specify the air volume fraction at each grid point at the inlet (as a function of time)? Thanks! Pei-Ying Hsieh |
July 17, 2014, 17:38 |
Interface curvature computaion in VOF
Rajesh Singh
Rep Power: 15 |
I need to calculate force at the interface in VOF simulation. Using CSF model, one need to compute the curvature of the interface. Can any one help me to write fluent UDF for this. I will really appreciate for this. Rajesh |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
