discrete phase model boundary conditions: problems using "Trap"
Old   December 4, 2014, 12:35
Default discrete phase model boundary conditions: problems using "Trap"
giorgio
giorginho90 is on a distinguished road
Hi to everybody! with Ansys Fluent, i would like to simulate the blockage of particles. I want to force particles to stop when they hit a certain surface. If i set "trap", they disappear from the doman. I want to accumulate particles there in order to have a reduction of the hydraulic diameter...could you help me? can i solve this problem with UDFs? I'm not so expert with CFD...thank u!
giorginho90 is offline   Reply With Quote
Old   December 4, 2014, 13:52
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Trap is what you need. Escape makes them disappear from domain...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 4, 2014, 16:04
giorgio
First of all thank U for the answer. The problem is that i want the particles to remain there and accumulate..in order to influence the continue phase. If i set Trap the particles dont remain there! Am i wrong?
Old   December 4, 2014, 16:11
diamondx's Avatar
Ghazlani M. Ali
I understood. Trap is what you need ! I don't understand what it does not work
Regards,
Ali
Old   December 4, 2014, 16:19
giorgio
I want to simulate the blockage of a channel due to Particles clogging, so i created and internal boundary. Which type of boundary do i have to select for this internal boundary? I was thinking Porous zone(porous jump in 2D) in order to allow the flow of the continue phase and block only particles by setting Trap for the DPM. Do u think it works? Thank u for the ready answer!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Modeling interface of fluid and porous, not with default setting ftab CFX 27 May 20, 2014 06:58
about compresive phase James CFX 10 September 12, 2006 03:16
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
