natural convection
Like Tree4Likes
  • 1 Post By virendra_p
  • 1 Post By windykawis
  • 2 Post By aquac
Old   September 7, 2014, 08:06
Default natural convection
Other
bachga is on a distinguished road
hello everyone,
i'm having a problem with the convergence of the result of the simulation of the natural convection. Are there anyone have experience about it?
bachga is offline   Reply With Quote
Old   September 8, 2014, 01:38
Default hi
Virendrasingh Pawar
virendra_p is on a distinguished road
i have some experience in multiphase buoyancy flows but not in natural convection.
Anyways i'll share few things:
1) My problem was flow through a pump sump ( open channel with pump at end) with surface air suction. This particular setup was very sensitive to initial solution so i first converged the solution with single phase setup and then used fluent's 'interpolate' feature to initialize the multiphase setup. Convergence issues were solved by this approach.
If this process makes any sense in your problem, please try it out.
2) I found that steady state simulations produced absurd results so i had to stick to transient simulations.
3) At the end of this html file you'll find some guidelines for high Ra flows, see if that helps. html --> http://aerojet.engr.ucdavis.edu/flue...ug/node572.htm
bachga likes this.
virendra_p is offline   Reply With Quote
Old   September 11, 2014, 05:58
Kawis Somp
windykawis is on a distinguished road
I also have an experience about natural convection but not sure that model is correct.
I used boussinesq model and specified operating density in operating condition.
bachga likes this.
windykawis is offline   Reply With Quote
Old   September 17, 2014, 06:31
Other
i also use boussinesq model for density but i think the operating density was defined in the properties of the material for fluid which i use here is oil. My problem is heat transfer by natural convection in the transformers. Do you have any idea about it?
Old   September 17, 2014, 11:50
aquac is on a distinguished road
Reduce the under-relaxation factors under Solution Controls -> Under-Relaxation Factors. Cut the Pressure and Momentum factors by half and take down the Energy factor to 0.8 or lower if necessary. Re-initialize if the solution doesn't seem to be converging.
You can also try playing with gravity; set it at -1 and see if it seems to converge; increment it steadily till you converge at -9.8.
Another thing to try is Adapting the mesh...go to Adapt->Region and manually adapt some part of the mesh.
Make sure you're using PRESTO! discritization for pressure
If all else fails, disable solving for the Flow equations under solution controls and try just solving for Energy first.
Natural convection (and buyoncy driven flows in general) are some of the hardest simulations, so you have to be resilient. Expect having to run thousands of iterations to get a solution.
Hope that helps.
windykawis and bachga like this.
aquac is offline   Reply With Quote
Old   September 17, 2014, 11:54
Other
Thank you . I'll try it now
Thermophysical properties for natural convection Ciefdi OpenFOAM Running, Solving & CFD 0 November 7, 2013 11:44
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Natural Convection Problem - Helium marzoa STAR-CCM+ 0 April 18, 2011 14:12
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 04:22
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
