Can the interface handle vortex?
Old   October 8, 2014, 07:58
Default Can the interface handle vortex?
Yolk
Yannian is on a distinguished road
I want to simulate a vortex going towards the propeller by MRF. I want to know whether the interface between rotating and stationary domain can transfer the vortex? Now it seems that it doesn't work, and the vortex can't be transfered continuously through the interface.
Yannian is offline   Reply With Quote
Old   October 8, 2014, 10:09
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Yes, there are no problems..
I'm attaching a simulation with mrf of an impeller and vortex formation.
ghost82 is offline   Reply With Quote
Old   October 8, 2014, 10:29
Yolk
Thank you for your reply. It is a really positive news to me.
I saw this case in CFX tutorial before, and is your computation in CFX as well? I am using Fluent now, i don't know whether there is difference for these two codes dealing with the interface. I can't get good result from Fluent untill now.
Old   October 8, 2014, 10:36
ghost82's Avatar
Rick
I used Fluent for the simulation.
Daniele
Old   October 8, 2014, 11:01
Yolk
Daniele
Hey Dani,
I explain to you my case and you can have a better understanding.
I build the propeller in a rotating domain and the rest is stationary domain. My stationary domian is not axisymmetrical because i am simulating a propeller running near the ground, and there is a ground in the stationary domain which is close to the propeller. There is vortex from the ground to the propeller.
Do you have any clue what can casue the vorticity not continuous? i have even tried conformal mesh because i thought the problem is due to the 'hanging' nodes. However it doesn't help.
Old   October 8, 2014, 11:51
ghost82's Avatar
Rick
Post some pictures (contours) of what you obtained and what you think to obtain
Old   October 8, 2014, 14:22
Yolk
The flow domain and the vorticity isosurface are in the attachment and could you please have a look.
Old   October 8, 2014, 14:31
Yolk
As you can see from the vorticity isosurface and axial velocity, the flow is not continuous at the interface.
Old   October 9, 2014, 03:51
ghost82's Avatar
Rick
Hi Yolk,
First question is: are you sure your solution is converged?
I know, also from the fluent user guide, that some discontinuities could be present across the interface, however, if you did not try, you can avoid interface for mrf calculation (i.e. connect in pre processing the faces shared by the rotor/stator) and see what's happen.
Daniele
Old   October 9, 2014, 05:12
Yolk
Hi Yolk,
Daniele
Hi Dani,
I would say the solution is converged: first, the thrust on the propeller is converged; second, the vortex strength on the ground is converged.
I still think the problem is from the interface. Now i am trying a simple case by adding a vortex in the inlet and let it go from a stationary to a rotating domain, and see what happens.
How can you connect the faces shared by two domains in FLUENT?
Yolk
Old   October 9, 2014, 05:14
ghost82's Avatar
Rick
You can't in fluent; you have to go back to preprocessor, connect the faces and remesh the domain.
You still have the two fluid domains (rotor and stator) but they share adjacent faces, instead of having interfaces.
Daniele
Old   October 9, 2014, 05:20
Yolk
Daniele
Okay, I see your point. When building the geometry, the two domains are combined under one part. There will be two domains in the ANSYS mesh, but there is only one face between the two domains. The face shared by two domains becomes interior in FLUENT boundary set up.
Old   October 9, 2014, 05:26
ghost82's Avatar
Rick
Yes, I don't use ansys meshing, but your description is ok.
Old   October 9, 2014, 08:00
Yolk
I tried the case with vortex from the inlet and vortex goes through stationary and rotating domain. The vorticity isosirface seems continuous although there is some discontinuity at the interface. The mesh doesn't have interface and there is interior face between two domains. So i think you are right that the interface can transfer the vortex. One issue is that the interface in this case is a plane not a circular surface, and maybe the circular surface makes the problem more difficult. Anyway, i will try the latter cace later.
Old   October 10, 2014, 03:27
Yolk
Hey Dani,
I upload two images with circular interface perpendicular to the vortex axial velocity. In the case for the first image without frame motion in the inner domain, the vortex can go through it continuously, In the case for the second image with frame motion in the inner domain, the vortex can't go through it continuously, and the vortex isosurface shown here looks like the image I showed before.
I think the circurlar interface, and rotating frame together make the vorticity with discontinuity. Do you have any idea how can solve this problem?
File Type: jpg no_framemotion_cylinder_perpendicular.jpg (30.8 KB, 19 views)
Old   October 10, 2014, 06:14
ghost82's Avatar
Rick
But in the second picture, I think you are rotating the domain around y axis, don't you? If so, I think it's correct that the vortex is broken.
Daniele
Old   October 10, 2014, 07:06
Yolk
Daniele
Yes, you're right, the axis of the rotating frame is in the y direction. Why do you say that the vortex is broken is correct? My intention is to let it go through the inner cylinder. Is there a reason for its breaking?
Old   October 10, 2014, 07:54
ghost82's Avatar
Rick
Well, I don't know...usually mrf, as you already know, is used to take a "snapshot" of a transient simulation, in which inside the rotor there are moving parts.
But in your test case there aren't rotating parts inside the rotor zone (the rotor is empty), so I think that this is not the correct approach to see is the vortex is broken at the interface.
Maybe that cells in the rotor are rotating with the assigned rotational velocity, so I wrote that it is correct that the vortex is broken.
To see if the cells are rotating post a contour plot of velocity in a xz plane.
Old   October 10, 2014, 08:38
Yolk
Hey Dani,
I don't think the cells in the inner domain is rotating from the velocities.
Old   October 10, 2014, 08:48
Yolk
A new case without inflow vortex in the outdomain and with frame motion in the inner domain is presented. There is vorticity from the inner cylnder.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
