How to extract the net reaction rate of ch4 from the fluent?
Like Tree1Likes
  • 1 Post By pilakin
Old   October 15, 2014, 05:03
Question How to extract the net reaction rate of ch4 from the fluent?
Small Mayi
ChenZhan is on a distinguished road
Dear everyone, thanks for your attention.
Recently, i am studying the eddy dissipation concept model (EDC model) in the fluent help. And a particular parameter, net reaction rate or reaction source term, is very concerned for me. I want to extract it from the calculated results, yet i am not success. Can you give me some suggestion? Here, some questions are listed following:
1. Is there a special model macro which can do this work by fluent itself;
2. If no such macro exists, how to do this work.
3. If we use the fluent help, for instance, with equation 7-30 in the theory guide of fluent, why it can not provide a consistent result when i compare it with the fluent reports. Is there a discrepancy between the net reaction rate and reaction rate term appearing in the equation 7.1, i.e. the result calculated by equation 7-30.
Any help will be very appreciated for me, thanks, good luck,my frieds.
ChenZhan is offline   Reply With Quote
Old   October 21, 2014, 08:38
pilakin is on a distinguished road
You can activate additonal output values in Solution->Run Calculation->Data File Quantities
Maybe what you're looking for is in there?
ChenZhan likes this.
pilakin is offline   Reply With Quote
Old   October 22, 2014, 02:04
Small Mayi
Thanks,pilakin.
The calculation has been carried over, so i do not want to take it again. Alternatively, i want to used the UDF together with the script function to extract net reaction rate out of the results. The most difficult for me is that it is not accertain to get the result of net reaction rate calculated by fluent. In the fluent help, it provides 2 reference on the EDC model, yet none is completely consistent with that presented in the help document. I am really very confused for that which formular used in the fluent code. In addition, it is not very clear what is the difference between the net reaction rate and the reaction source term. In my opinion, they should be same with each other. In other words, if i used the formular 7-30 in help document to calculate the reaction source term, it should be equal to that presented by the fluent :Result=>Reports. However, in fact, they are not the same. Why, i can find the answer. If i obtain the formular for net reaction rate used by fluent, so it is convenient to output this result with my UDF in the form of batch mode.
Thanks, againe.
Old   November 23, 2014, 22:33
Question
Small Mayi
If you have a better understanding of this subject, please help me.Thanks my friends. Any suggestion will be very appreciated.
edc model, net reaction rate, reaction rate terms
Fluent UDF urgent! Variable reaction rate natantyt Fluent UDF and Scheme Programming 8 October 17, 2021 03:35
PaSR + infinite reaction rate in reactingFoam --> no reactions occurring tatu OpenFOAM Running, Solving & CFD 2 November 24, 2016 18:34
ISAT reaction rate error for modeling the flare Rouzbeh1360 FLUENT 10 May 15, 2014 08:45
write forward, reverse reaction coefficient, reaction rate in ChemFoam hismother OpenFOAM Running, Solving & CFD 3 November 7, 2012 03:33
Surface reaction rate temperature dependence tumbao FLUENT 1 February 17, 2011 09:14
