October 18, 2014, 00:27 |
3D Annulus Cylinders
CR-7
Rep Power: 14 |
Hi all of you
I'm working on concentric and eccentric annulus using nanofluids. My issue is with laminar flow (Re = 100-1500) and specify the gravity the solution did not converge. without applying the gravity had good convergence and the heat transfer coefficient as follows h = 28 without gravity h = 30 with gravity How to deal with this issue as I have to study the buoyancy force??? |
October 20, 2014, 10:37 |
Andrew Kokemoor
Rep Power: 13 |
You might have some luck with different Pressure-Velocity coupling or pressure discretizations, particularly Body-Force-Weighted.
2d 1/2 axisymmetric annulus for POLYFLOW | j0hn04 | ANSYS Meshing & Geometry | 2 | March 7, 2020 12:55 |
Simulating flow for rotating cylinders with a stationary body in the annulus | diwakaranant | SU2 | 5 | December 10, 2013 05:09 |
Wake behind a two crossing cylinders | Heini | FLUENT | 0 | May 8, 2013 16:54 |
2D Aerofoil with rotating cylinders - Help & Advice! | Bluejay | OpenFOAM | 1 | December 31, 2012 04:40 |
[ICEM] generating tetra mesh on various cylinders at the same time | karananand | ANSYS Meshing & Geometry | 2 | July 9, 2010 16:34 |
