Condensation in a closed thermosyphon??? (heat pipe, evaporation-condensation)) |
October 20, 2014, 18:59 |
Xiaobing Zhang
Rep Power: 12 |
I'm modeling phase change flow in a closed thermosyphon. Now my status is having evaporation in my evaporator. But little condensation is found in the cold part. The following pics are my results. I calculated 200s already, but condensation is still very small. Any guidance or help will be appreciated. Thanks, Xiaobing Limited condensation happens in the condenser. Limited condensation happens in the condenser. Evaporation is good. |
April 7, 2015, 15:19 |
Udf
Muhammed Asmail
did you use UDF for heat and mass transfer ??
i am not get on condensation ??!!! i do not know why? |
December 12, 2015, 22:35 |
evaporation condensation in fluent
Ram Kumar Pal
Rep Power: 11 |
Hello friends, I have written UDF for phase change in thermosyphon, boiling is happening inside evaporator but there is no condensation inside condenser, I'm confused why this error is happening. I'm writing UDF below, please notify me what is the error in UDF.
#include "udf.h" #include "sg_mphase.h" #include "mem.h" #include "metric.h" #include "flow.h" #include "sg.h" #define T_SAT 373 #define LAT_HT 2455e3 DEFINE_SOURCE(vap_src,cell,pri_th,dS,eqn) { real m_dot_v; Thread *mix_th, *sec_th; mix_th = THREAD_SUPER_THREAD(pri_th); sec_th = THREAD_SUB_THREAD(mix_th,1); /*m_dot_v=0.0;*/ if (C_T(cell,mix_th)>T_SAT) { m_dot_v = 0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*(C_T(cell, mix_th)-T_SAT)/T_SAT; dS[eqn] = 0.0; } else if (C_T(cell,mix_th)<T_SAT) { m_dot_v = -0.1*C_VOF(cell,pri_th)*C_R(cell, pri_th)*(T_SAT-C_T(cell,mix_th))/T_SAT; dS[eqn] = -0.1*C_R(cell,pri_th)*(T_SAT-C_T(cell,mix_th))/T_SAT; } return m_dot_v; } DEFINE_SOURCE(liq_src,cell,sec_th,dS,eqn) { real m_dot_l; Thread *mix_th, *pri_th; mix_th = THREAD_SUPER_THREAD(sec_th); pri_th = THREAD_SUB_THREAD(mix_th,0); /*m_dot_l=0.0;*/ if (C_T(cell,mix_th)>T_SAT) { m_dot_l = -0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*(C_T(cell, mix_th)-T_SAT)/T_SAT; dS[eqn] = -0.1*C_R(cell,sec_th)*(C_T(cell,mix_th)-T_SAT)/T_SAT; } else if (C_T(cell,mix_th)<T_SAT) { m_dot_l = 0.1*C_VOF(cell,pri_th)*C_R(cell,pri_th)*(T_SAT-C_T(cell,mix_th))/T_SAT; dS[eqn] =0.0; } return m_dot_l; } DEFINE_SOURCE(enrg_src,cell,mix_th,dS,eqn) { real enrg_dot; Thread *pri_th, *sec_th; pri_th = THREAD_SUB_THREAD(mix_th,0); sec_th = THREAD_SUB_THREAD(mix_th,1); if (C_T(cell,mix_th)>T_SAT) { enrg_dot = -0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*LAT_HT*(C_ T(cell,mix_th)-T_SAT)/T_SAT; dS[eqn] = -0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*LAT_HT/T_SAT; } else if (C_T(cell,mix_th)<T_SAT) { enrg_dot = 0.1*C_VOF(cell,pri_th)*C_R(cell,pri_th)*LAT_HT*(T_ SAT-C_T(cell,mix_th))/T_SAT; dS[eqn] = -0.1*C_VOF(cell,pri_th)*C_R(cell, pri_th)*LAT_HT/T_SAT; } return enrg_dot; } |
December 14, 2015, 09:22 |
Udf
#4 | |
Muhammed Asmail
Dear rampal
your Ansys-Fluent is original version?? I mean original from the company no commercial that it is bought from the market case of heat pipe is very complex and it needs original license and the condensation will not appear to you if the Ansys not original version as it happened with me through 8 months and i did not get result Ansys can solve simple cases if it is not original version but heat pipe is complex case and it needs original version i hope that you understand me many thanks Mohammed Quote:
June 17, 2016, 09:43 |
#5 | |
SHUJAN
Rep Power: 9 |
July 5, 2016, 12:47 |
#6 | |
Przemek
Can you send errors you got?
best regards pblasiak |
July 14, 2016, 12:02 |
#7 | |
Przemek
Did you model this with UDF or built-in Fluent model?
July 27, 2016, 11:37 |
#8 | |
Przemek
Have you solved your problem with no condensation? I have the same problem. Please see here: http://www.cfd-online.com/Forums/flu...on-doesnt.html
October 18, 2016, 13:18 |
Rep Power: 9 |
Anyone succeed to simulate the heat pipe evaporator and condenser?
I'm doing my bachelor project on it and i will appreciate any help in this case because, i'm beginner with fluent however, i know the equations of energy and momentum which need to be written in the udf but i failed to simulate it. |
December 21, 2016, 11:25 |
Heat Pipe
Reza
Hi everyone. I am new in the two-phase flow and heat pipe field and I should simulate a wicked heat pipe by OpenFoam. It is appreciated if anyone can help me ... Thanks
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 12:44 |
heat transfer along a pipe | lysander | FLUENT | 0 | July 27, 2012 23:39 |
evaporation and condensation | aximefu | CFX | 4 | May 13, 2012 23:09 |
Evaporation and heat pipes | Energy | FLUENT | 6 | November 5, 2011 10:50 |
