Unsteady residual???
Old   October 27, 2014, 08:14
Default Unsteady residual???
le hoang anh
lehoanganh07 is on a distinguished road
Hi, I am doing unsteady calculation with LES turbulence model. From the fluent guid, I saw that the residual should reduce 3 order within each time step or reduce as the flat. I am not really clear about that.
1. Do we need to set critical convergent in monitor panel for transient calculation or change it to none?
2. Does residual effect the sulution?
3. This is the residual of my calculation. Is this ok?
Thank you!
lehoanganh07 is offline   Reply With Quote
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
