November 13, 2014, 09:20 |
errors when reading mesh in Fluent
chuang zhou
hello
when I import the mesh to fluent, the following error shows up. Cleanup script file is C:\\Users\\ansys\\cleanup-fluent-AMAZONA-054EPQC-544.bat > Reading "C:\Users\ansys\Desktop\Fluent_mesh\mesh_2.msh "... 525087 nodes. Error: read: face 1, zone 3. Reading Faces: failed while reading section 13. Clearing partially read grid. Error: Read_Grid_Section: Aborted due to critical error. Error Object: #f Error: Error reading "C:\Users\ansys\Desktop\Fluent_mesh\mesh_2.msh ". Error Object: #f Error: C:\PROGRA~1\ANSYSI~1\v145\fluent\fluent14.5.7\win6 4\3d\fl1457s.exe received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: #f why I got this error? wish your help. thanks all |
error while reading mesh in fluent | swapna | FLUENT | 12 | January 27, 2018 22:37 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam | jlpelerin | OpenFOAM Meshing & Mesh Conversion | 4 | April 25, 2011 16:56 |
Can Fluent handle a degenerate block? Error while reading mesh... | Anorky | FLUENT | 1 | May 1, 2010 12:47 |
