Need comment about y+ value in my calculation
Old   December 5, 2014, 02:26
Default Need comment about y+ value in my calculation
Anh
dinhanh is on a distinguished road
Hi, I am doing the calculation in 3-D nozzle. I use serverals turbulence model: k-epsilon with enhanced wall treatment, SST k-omega model, k-kl-omega model, SAS model, DES model and LES model.
The y+ of whole domain is within viscous sublayer (y+<4.5) and most of them is less than 1, except some point y+ reach to 7.
With enhanced wall treatment, people sugess that y+ must be in order of 1, but also y+< 5 is OK. SST k-omega model also but, form the paper of Menter, this model can do with any range of y+.
For DES model, I used DES-SST model, which is from Spalart paper, he said that y+<5 is good enought for DES-SA model and DES-SST model can be higher value of y+.
For LES model, wall modeling I use Wengler model, which can capture with coars grid and highter y+.
This is the picture show the y+ in my calculation. Specilally, in the nozzle region, the y+ in the flow direction is almost less than 1, except some points go to 1.5 (block2 wall and block2 side wall).
So how do you think about this y+ value? How will it influent the solution?
dinhanh is offline   Reply With Quote
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 09:04
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
Cavitation transient calculation inside a nozzle - need comment about the residual dinhanh FLUENT 14 March 9, 2016 03:43
Warning 097- AB Siemens 6 November 15, 2004 04:41
