December 9, 2014, 20:48 |
Flow in an Orifice Meter
Rep Power: 11 |
Hi!
I am running a 2D steady turbulent simulation for a flow through an orifice (D=90mm, Beta=0.35, V_in=1.01m/s), I am quite unclear as to which solver to use between coupled and segregated? Should I use pressure-based or density-based? Thanks in advance y'all ! |
December 10, 2014, 10:58 |
Lucky
Rep Power: 66 |
Assuming the fluid is air-like, the throat Mach number seems low for an orifice (M~0.03). Since it seems the flow is incompressible, I think you can get away with using the pressure based solver.
The continuity, momentum, and energy equation, if used, are always coupled in the density based solver. Any of the P-V coupling in the pressure-based solver can be used: SIMPLE or PISO if segregated or coupled. The difference in the P-V coupling schemes mostly affects the number of iterations until convergence. |
December 10, 2014, 12:40 |
Rep Power: 11 |
Thanks for the tips, much appreciated
solver pressure density |
Running a simple flow through an orifice | raghav.venky | OpenFOAM Running, Solving & CFD | 6 | September 4, 2020 08:50 |
Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 06:12 |
How to simulate Choked Flow in Orifice? (URGENT) | kaegen | FLUENT | 2 | July 10, 2010 18:19 |
[ICEM] Meshing wedge-type flow meter | negronson | ANSYS Meshing & Geometry | 2 | February 23, 2010 00:36 |
lenght and number of nodes for an orifice meter flow problem - k-eps model | fofo | FLUENT | 0 | November 15, 2009 03:49 |
