Compression Corner Shock Wave Turbulent Boundary Layer Interaction |
January 28, 2015, 04:31 |
Saeedur Rahman
We have been trying to simulate the https://www.aem.umn.edu/people/facul...rishpaper2.pdf paper. We are using Fluent 14.5 (2d, dp, dbns imp, sstkw) to simulate the compression ramp. Boundary conditions- Inlet and upper boundary(pressure farfield),wall(no slip, constant temperature), exit(pressure outlet) with turbulence parameters from the paper(w_inf=10*u_inf/L,k_inf=.01*nu_inf*w_inf).
But the problem is that the separation starts 2.688 cm before the corner in the paper while we found it starting 14 cm before the corner. The separation bubble length is also correspondingly much bigger. We have attempted to solve it by trying a few things but the separation start and bubble length is always much bigger. We are stuck here and desperate to find a solution. Could anyone please help? |
compression corner, swtbli |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Formula for velocity in buffer layer of turbulent boundary layer | nickvinn | Main CFD Forum | 0 | February 3, 2012 11:57 |
Turbulent boundary layer resolution | deji | OpenFOAM | 2 | June 15, 2011 13:57 |
Boundary conditions for turbulent boundary layer | Thomas | FLUENT | 1 | June 17, 2008 05:14 |
Roe Scheme; Shock Boundary layer Interaction | Mohammad Kermani | Main CFD Forum | 5 | December 20, 1999 15:44 |
