Compressible flow boundary conditions
Old   October 23, 2015, 06:36
Default Compressible flow boundary conditions
AnaE is on a distinguished road
I am trying to analyse the behavior of the engine exhaust gas in a structural facility, with wind conditions.
For the effect I am using compressible flow, but I am having trouble in the boundary conditions in the volume of control. I was thinking about velocity inlet and pressure outlet, however that is not valid for compressible. I have tried pressure inlet and pressure outlet, and mass flow inlet and pressure outlet however nothing is working very well.
Any suggestions?
Thank you
AnaE is offline   Reply With Quote
Old   October 24, 2015, 14:02
Lucky
A pressure inlet and pressure outlet pair are generally the most robust. For compressible flows you'll have to specify the inlet stagnation pressure (& stagnation temperature). If you need a particular mass-flow rate then use the target mass flow rate option on the pressure outlet. If this doesn't work, then you're probably doing something wrong.
Old   October 26, 2015, 07:01
This issue is - I do have convergence, but the problem is symmetrical and I am obtaining asymmetric results for the airflow. That only happens in 2nd order. I am using pressure standard and the results are getting better, but I don't understand the reason behind it.
Old   October 28, 2015, 09:09
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Can you post some pictures?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
boundary conditions, compressible
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Radiation interface hinca CFX 15 January 26, 2014 17:11
Boundary conditions for compressible flow cici Main CFD Forum 1 April 29, 2013 01:03
compressible flow boundary conditions yangqing FLUENT 2 January 22, 2002 10:19
