How to track spray liquid\gas phases (for DPM source)?
Old   March 21, 2015, 08:33
Default How to track spray liquid\gas phases (for DPM source)?
Jasmine
Jasmine :) is on a distinguished road
I'm new to Fluent and will appreciate your advice and help.
The problem that I work on considers a non-premixed spray fuel combustion with air, using DPM for fuel injection.
I'd like to trace the fuel liquid mass fracture in the spray stream (liquid+gas) as it evaporates (until it is fully evaporated and burned)
Thanks!
Jasmine :) is offline   Reply With Quote
Old   March 23, 2015, 01:18
Paritosh Vasava
vasava will become famous soon enough
You can check mass fractions via Contours-->Species-->Mass Fraction of *.*. Also you can trace the DPM particles with Particle Tracks.
vasava is offline   Reply With Quote
Old   March 23, 2015, 07:20
Jasmine
Thanks,
Within a specific material, how can I distiguish a liquid phase mass fraction from gas\evaporated phase?
Does a mass fraction (contours\xy\..) of that material represent liquid phase only, or all phases?
Old   March 24, 2015, 02:40
Paritosh Vasava
You can chose the species for which you want to see the mass fraction. Depending on your setup you should be able to see all the species participating in the simulation.
spray combustion
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
