March 10, 2015, 21:19 |
Mesh Generation Problem
Davut Vatansever
Rep Power: 11 |
I am new to CFD and i have a project regarding design and analysis of a microjet engine's turbine.The turbine need to be radial-flow and has about 200mm diameter,modeled in catia. When i give any thickness to turbine blades ,it exceeds from the other side of the hub so the mesh generation cannot be accomplished ,whereas in 2D,mesh is easly obtained but this time i can't select both side of the turbine surfaces as solid wall boundary condition.So,fluent is unable to recognise the fluid domain. I am attaching jpeg of .part file. Any help would be appreciated |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
Problem with mesh generation | Nestor | FLUENT | 3 | November 1, 2006 02:54 |
Mesh generation problem | Lam | FLUENT | 2 | December 25, 2003 12:37 |
