How to stop Workbench Fluent simulation in the middle |
March 19, 2015, 09:40 |
Pierre
Rep Power: 11 |
I use Workbench to run Fluent simulations. But once I start it, it seems there’s no way to either monitor the simulation or stop the simulation in the middle?
Could anyone tell me how to do them? |
March 20, 2015, 01:30 |
Miro
Rep Power: 13 |
you could pass output to a log, i.e.:
fluent 2ddp -g -i journal.jou > log.fluent for linux. On win. I don't know |
March 20, 2015, 10:40 |
Andrew Kokemoor
Rep Power: 13 |
In 15.0 and later, you can right click the Solution component in the project page in Workbench and select Show Solution Monitoring. This will plot the residuals and other monitors you've defined.
If you want to stop a solution while it's running, click the Show Progress button at the bottom right in Workbench and then the red button at the right in the progress pane. |
Fluent does not launch from workbench | NickyNac | FLUENT | 8 | April 13, 2018 09:42 |
FLUENT installation on UBUNTU 12.04 (LTS) | teymourj | FLUENT | 2 | March 1, 2017 22:24 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
LSR (Land speed record) car simulation on FLUENT | Maxime31850 | FLUENT | 2 | May 1, 2013 11:15 |
How stop simulation if convergence is not reached? | Andreas | FLUENT | 0 | October 16, 2007 12:35 |
