How to set minimum number of iterations in Fluent? |
March 21, 2015, 01:44 |
Pierre
Rep Power: 11 |
Sometimes we need to set a minimum number of iterations the simulations shall run. How to set that up in Fluent? CFX has this option but I didn’t find it out in Fluent.
March 21, 2015, 06:41 |
Rep Power: 18 |
If there are no settings to restrict the minimum number of iterations, then you could remove the convergence criteria, run for x iterations and then turn the convergence criteria back on.
March 21, 2015, 08:36 |
Pierre
Rep Power: 11 |
Sometimes I run hundreds of simulations by Workbench. I can't do that manually for each of them. Is there a better way to achieve that?
March 21, 2015, 17:03 |
Rep Power: 18 |
Ok, to automate this process, have a read of this article on using Scheme and a UDF; use the rp-variable as an iteration counter (and when it reaches x, set the convergence criteria on).
March 22, 2015, 19:34 |
Lucky
Rep Power: 66 |
As far as I know, there's no setting for minimum number of iterations.
I've also just turned off all convergence monitors until the minimum iterations has been reached and then turned them on. This is fairly straightfoward to do using TUI or a journal file so it is not cumbersome. It would be a nice feature to have in future versions, especially for unsteady simulations is a very useful feature to have. |
May 23, 2018, 11:06 |
#6 | |
Johann Möller
I know this a fairly old thread, but hopefully you can still help me. I am trying to do the same the same as you - turn off all my convergence monitors and only turn then on after the minimum number of iterations - but I am struggling to manage. How did you do it? Thanks |
May 23, 2018, 14:33 |
Lucky
Rep Power: 66 |
You can't do it. You have to do it manually. That means run it with all monitors off, and then turn on the monitors and run again.
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
