radiation efflux
Old   June 12, 2015, 00:01
Default radiation efflux
sachin kumar
sachin kumar is on a distinguished road
I am simulating hypersonic flow(M = 7) over a blunt body. pressure farfield BCs is applied, and the walls of blunt body have heat flux BCs (q = 0). The top surface of the blunt body is subjected to radiation efflux (heat rejected in the form of radiation) the governing equation is [q(convection) - q(radiation) = 0] it will give me the temperature on the surface. I have used P1 model to consider the radiation and give internal emmsivity = 0.84, and compare the temperature with surface without radiation. the temperature is less in case of with radiation. but in postprocessing there is option called radiation incident, when i plot radiation incident there is a significant value. but in my problem there is a possibility of only radiation emission not incident.
so can any one tell me what is this incident radiation.
can i consider it as a amount of heat flux incident on the surface which is responsible for temperature generation.
if i am wrong with the procedure used to consider radiation, then can u please tell me the right way to consider radiation(rejection)
thanks in advance
sachin kumar is offline   Reply With Quote
radiation flux rejected from surface sachin kumar Main CFD Forum 1 June 16, 2015 02:43
Radiation Modeling Chris89 CFX 20 August 14, 2014 07:51
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 04:12
Multiphase radiation in CFX Luk_Fiz CFX 5 March 17, 2009 03:51
