Nusselt number calculation
Old   June 18, 2015, 09:03
Default Nusselt number calculation
goku
naruto5255 is on a distinguished road
Hi
I am new to fluent trying to learn ansys by some simple cases
My problem is simple a circular pipe with inlet velocity 0.5m/s and temperature is 15c wall thickness is zero(only fluid domain) (laminar flow) constant wall temperature is 500 K pressure outlet is zero pascal.how to calculate the heat transfer coefficient and nusselt number for this flow?
How to plot nusselt number vs direction vector (in flow direction) because nusselt number changes in thermal entry length? and how to plot the heat transfer coefficient along the flow direction ?
Thanks
Naruto
naruto5255 is offline   Reply With Quote
Old   June 18, 2015, 09:23
liusuanyatong
liusuanyatong is on a distinguished road
You can refer to this post。http://www.cfd-online.com/Forums/flu...packe-bed.html
liusuanyatong is offline   Reply With Quote
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 18:32
Nusselt Number calculation in Ansys CFX azurespirit CFX 36 December 3, 2016 19:29
calculation of average nusselt number along a wall surface abhishek.iiest FLUENT 0 June 11, 2015 02:38
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
