UDF defining transient boundary condition
Old   June 20, 2015, 04:12
Default UDF defining transient boundary condition
Jordi Pina
jpina is on a distinguished road
I'm trying to develop a UDF for defining the fluid velocity in the inlet boundary condition.
However, the velocity is transient, and at each time step the velocity profile is defined by a polynomial.
For example:
v(time_step_0)=-1.0988e4x^2-27x-0.0155
v(time_step_1)=-8.82e3x^2-18.93x-0.01
etc.
I have a matrix of coefficients where each column suits to the polynomial's coefficients of each time step.
I would appreciate some orientation concerning to how to develop the UDF.
Thanks a lot!
jpina is offline   Reply With Quote
Old   June 23, 2015, 11:31
Jordi Pina
Someone could give me a hint?
Old   June 23, 2015, 11:41
Llume is on a distinguished road
You need to define an UDF, a C code for example and define it in fluent. Your scripts needs to look like something like this:
#include "udf.h"
DEFINE_PROFILE(unsteady_velocity, thread, index)
face_t f;
real t = CURRENT_TIME;
begin_f_loop(f,thread)
F_PROFILE(f,thread,index) = 1+15*t+15*t*t;
end_f_loop(f,thread)
but you need to specify also a dependency on the position of the center of the faces where you want to specify the inlet condition if you wish to do so. To understand the code and how to modify it to include this you should refer to the UDF manual.
Llume is offline   Reply With Quote
Old   June 23, 2015, 11:54
Jordi Pina
Hi Llume!
Maybe I didn't explain myself correctly.
I have a polynomial for each time step, I do not have a function v=f(position,time)!
My aim is to develop a UDF where:
- At time step 1:
v= 2x^2+3x+1
- At time step 2:
v=4x^2+4x+1
- At time step 3:
v= ...
Thanks!
Old   June 23, 2015, 12:00
The process would be the same, you need only to use an "if" to check at which timestep the simulation is and change the way the condition is evaluated accordingly, you can check the subsection "Fluent UDF and Scheme Programming" of this forum to see other examples.
This post has an UDF that could be a good starting point for you:
http://www.cfd-online.com/Forums/flu...llel-mode.html
Old   July 8, 2015, 12:23
Jordi Pina
Hello everybody,
finally I have succed on the UDF development.
I copy here the UDF with the aim to help somebody in the future:
UDF for specifying steady-state velocity profile boundary
condition
#include "udf.h"
DEFINE_PROFILE(unsteady_velocity_profile, t, i)
double coef_matrix[3][4];
face_t f;
int j;
double xy[ND_ND];
int curr_ts;
/*Manually copied data from MATLAB, must be automatized*/
coef_matrix[0][0]=-1.0988E4;
coef_matrix[1][0]=26.53;
coef_matrix[2][0]=0.;
coef_matrix[0][1]=-8.83E3;
coef_matrix[1][1]=-18.9;
coef_matrix[2][1]=-0.01;
coef_matrix[0][2]=-6.65E3;
coef_matrix[1][2]=-11.33;
coef_matrix[2][2]=-0.0047;
coef_matrix[0][3]=-4.49E3;
coef_matrix[1][3]=-3.74;
coef_matrix[2][3]=7.33E-4;
begin_f_loop(f, t)
curr_ts = N_TIME;
F_CENTROID(xy,f,t);
F_PROFILE(f,t,i)=-(coef_matrix[0][curr_ts]*(xy[1]+4E-
6)*(xy[1]+4E-6)+coef_matrix[1][curr_ts]*(xy[1]+4E-
6)+coef_matrix[2][curr_ts]);
end_f_loop(f, t)
Each column of the matrix is a time step and each row is a polynomial's coefficient.
See you.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Define_profile UDF for Transient Heat flux boundary condition Amoljoshi Fluent UDF and Scheme Programming 2 June 20, 2018 21:55
Using Transient Boundary condition raamek FLUENT 1 September 23, 2014 11:00
UDF for inhomogenous Neumann boundary condition akhilesh Fluent UDF and Scheme Programming 3 December 24, 2012 11:14
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
