solving the boundary and thermal layer
Old   August 14, 2015, 05:13
Default solving the boundary and thermal layer
thomas
thomas. is on a distinguished road
Hello all,
I am solving a 2D natural convection driven laminar flow case with some bubble generation due to boiling. In order to solve the velocity field properly, I have to solve the boundary and thermal layer, i.e., do some refinement of the mesh near the walls.
I had a thought: I could use either way a wall function to approximate the boundary layer effects on the flow in order to reduce computational cost (quite limited in my case), in spite of having a laminar flow.
I programmed a UDF function to keep the eddy viscosity at the same value as the molecular viscosity, I activated the k-e turbulence model, chose the enhanced wall treatment, I set up the boundary conditions (turbulence intensity=0 and turbulent viscosity ratio = 1) and ran the simulation. Result: even more computational cost.
So I got a step back an disabled the turbulence equation solver (solution controls > equations) and ran the simulation again. Result: a very similar solution to the solved-boundary-layer-case with a bit less of computational cost.
My question then is: as I disabled the turbulence equation solver, did I also disabled the use of the wall functions, or did I keep them?
I have gone through every userīs-guide and theory-guide manual and I havenīt been able to find an answer.
Thank you very much for your help in advance!
Bye.
thomas. is offline   Reply With Quote
Old   August 16, 2015, 12:42
Lucky
By freezing the turbulence equations (say k and epsilon) you may freeze the computation of the k and epsilon equations, but you do not prevent other parts of the computation. For example, the velocity wall boundary condition still has wall functions. The wall functions are still active on the energy equation if that wasn't also disabled. The calculation of y* is also not disabled.
I don't get why you're using a turbulence model if the flow is laminar. Shouldn't you just use the laminar solver rather than trying to bootstrap a turbulence model and trying to make it to act laminar? I don't get why if the flow is laminar, you're also trying to use (turbulent) wall functions to apply the boundary conditions, you should be applying the laminar wall boundary conditions.
LuckyTran is online now   Reply With Quote
Old   August 17, 2015, 02:50
thomas
first of all, thank you very much for your answer!
Regarding your questions your post, I have further questions and I will answer yours:
Q:
Where did you find that information? I have been searching for that everywhere!
A:
Because of two reasons. (1) The RPI wall boiling model needs a wall function, in order to calculate the quenching heat flux. (2) In stead of solving the laminar boundary layer - which has higher computational cost as a consequence, due to the mesh refinement near the walls - I could approximate it with a wall function, in order - as said before - to reduce computational cost.
I know that Fluentīs wall functions are for turbulent boundary layers, but according to my results (I have ran the same simulation with a proper cell refinement near the walls and with a coarser mesh using wall functions), the results are VERY similar.
Thanks very much in advance!
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Radiation interface hinca CFX 15 January 26, 2014 17:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
