August 16, 2015, 10:02 |
Boundary Conditions - Water Column
Dominik Bär
Hey Guys,
I try to reply an experiment with a bubble column. I built the Geometry(includes Mesh) with Ansys ICEM 16.1. Its a Round Pipe with a simple inlet, outlet an a cylinderwall. Now i try to integrate values in Fluent. My Problem: i should create a multiphase flow. The pipe should be filled with water at the beginning (HOW???) and gas should flow from the inlet to the outlet. How is it possible to fill this pipe before i start the simulation ?? Hope you can understand my problem. Thanks guys Last edited by Ace87; August 16, 2015 at 13:21. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
CGNS Boundary conditions using SU2 | denzell | SU2 | 3 | July 9, 2018 05:58 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Periodic boundary conditions for 2D pipe (water flow). | thess | FLUENT | 3 | May 31, 2012 13:38 |
