higher aspect ratio problem
Old   August 17, 2015, 03:43
Default higher aspect ratio problem
Mahmoud
Eng.Mahmoud abd elsalam is on a distinguished road
hi , everyone
i face the problem of higher aspect ratio and lower orthogonal quality and can not find any way to solve this problem ...
thank you advanced for any information
http://i.imgur.com/1Y8tfZ7.png
Eng.Mahmoud abd elsalam is offline   Reply With Quote
Old   August 17, 2015, 13:35
Mahmoud
is there anyone can help me ??
Old   August 18, 2015, 06:16
Xu Huang
xuhuang is on a distinguished road
Which soft ware do you use to genreate you mesh. I am using ICEM.
Can you show the grids near the tip of your model? I guess maybe the problem comes from there.
xuhuang is offline   Reply With Quote
Old   August 18, 2015, 06:46
Mahmoud
hi, xuhuang
also , i am using ICEM
this is grid near the tip
http://i.imgur.com/HKlPSeg.jpg
thanks xuhuang for your reply
Old   August 18, 2015, 06:55
Xu Huang
Is it possible to attach the ICEM files?
The picture does not show the details.
Old   August 18, 2015, 07:02
Mahmoud
ok .. these are ICEM files
http://www.mediafire.com/download/1z...ju/ICEMCFD.rar
Old   August 18, 2015, 07:25
Xu Huang
you set an order of 10^-6 for the first layer perpendicular to the wall surface, but an order of 1 along the surface.
Therefore, the aspact ratio is of order 10^6.
I check the angle, the minimum is 38 degree. This should be ok.
Why do you set such a small value perpendicular to the wall surface?
Old   August 18, 2015, 07:52
Mahmoud
first . i am sorry for repeating of posts
second .. i watched this tutorial
https://www.youtube.com/watch?v=9Bc0NBk-urM
and did it step by step , when reached the step to calculate the Y+ distance i put my inputs velocity and density of air then i put boundary layer length the chord of my blade (i think this is the mistake ) after , the value of estimated wall distance is 1.2e-6
Old   August 18, 2015, 08:23
Xu Huang
I think how fine the mesh near the wall depends on how you treat near wall region in your simulation. If you use fluent, you can check it in the theory guide.
for example,
standard wall function requires: the lower limit for y* in the order of y*~15.
enhanced wall function: typically with the first near-wall node placed at y+~1 is fine enough to be able to resolve the viscous sublayer
Good luck!
Grid Aspect Ratio harishameed33 Main CFD Forum 1 August 11, 2012 22:35
[ANSYS Meshing] How to Control Aspect Ratio in Ansys meshing mecbe2002 ANSYS Meshing & Geometry 0 May 28, 2012 07:56
[ICEM] check aspect ratio camoesas ANSYS Meshing & Geometry 2 November 14, 2011 09:38
[ICEM] Mesh along axis for a wedge gives elements with extreme aspect ratio sangrampp ANSYS Meshing & Geometry 0 November 17, 2010 06:57
aspect ratio ditto CFX 7 May 11, 2003 11:19
