Supercavitation problem
Old   February 28, 2012, 07:47
Default Supercavitation problem
emil
emteh is on a distinguished road
Hi! I'm working on a supercavitating hydrofoil. I made a simulation of the cavitating flow around the hydrofoil (2 phases, flow, turbulence, vapor equation). The “velocity inlet” is set to 25m/s, vaporization pressure to 1700Pa, density od water is 999kg/m3, density of water vapour 0,015 kg/m3, viscosity of water 0,00114 kg/ms, visc. of water-wapor 9e-10 kg/ms.
My problem is that the Cl and Cd of the supercavitating hydrofoil are enormous (Cl=200000 and Cd=6000) they should be a little higher than the Cl and Cd found with just turbulence modelling (Cl=3.5 Cd=0.07).
Any ideas?
Thanks
emteh is offline   Reply With Quote
Old   February 28, 2012, 16:51
spk
spk is on a distinguished road
Have you checked the reference values?
spk is offline   Reply With Quote
Old   February 29, 2012, 12:32
emil
The reference values are the same for the 2 simulations.
Area, velocity are set to 1
density to 1.225 kg/m3
Old   February 29, 2012, 17:26
spk
I'm not sure, but i think that area=chord length*hydrofoil depth,
velocity has to be set 25m/s and density has to be set 999kg/m3.
I' m looking forward for answers from other guys of the forum!!
Old   March 3, 2012, 21:21
Cool
emil
Yes of course! silly me!!! The „Cl“s of the SCHFoil and the one without cavitation are of the same order of magnitude if multiplied by the appropriate density. (999 kg/m3 for water and 0.015 for water vapor),
thanks
Old   August 29, 2015, 11:39
Unhappy supercavitation
Mohammad-reza is on a distinguished road
Hi
I want to simulate supercavitating flow around a hydrofoil for sigma=0.03 using CFX or Fluent.
But the cavity isn't closed and continue until the outlet boundary
Mohammad-reza is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
