September 16, 2015, 04:37 |
Call udf some Iterations
Eduardo Tola
Rep Power: 10 |
Hello to everyone!!
I would love to know if there is someone who knows how to call a udf every some iterations (compiled udf), for example 5, instead of every iteration. In order to not waste computer power, I want to call the function every 'X' iterations and no call every iteration and if a condition is reached then run the function. Thank you very much
Having fun with CFD =) |
September 16, 2015, 05:43 |
Bruno Machado
Rep Power: 12 |
what do you want to do? What you can do is add a counter base on the iteration and put it in an if statement.
September 16, 2015, 07:05 |
#3 | |
Eduardo Tola
Rep Power: 10 |
Thank you =)
September 16, 2015, 07:13 |
Bruno Machado
Rep Power: 12 |
so in that case you can add one counter
static int counter = 0.0; if (counter <5) { do nothing for example counter += 1.0; } else if (counter = 5) { do whatever you want; counter = 0.0; } You can do something like this in your execute at the end or adjust macro. |
September 16, 2015, 07:50 |
#5 | |
Eduardo Tola
Rep Power: 10 |
September 16, 2015, 07:56 |
Bruno Machado
Rep Power: 12 |
when the variable reaches 5 (for example), it will execute something and the variable returns to 0. from iterations 1 to 4 it wont do anything. I do not know how to code to do this only every X iterations, but you can say to do nothing in intervals. Not sure if I made myself clear.
September 16, 2015, 08:09 |
#7 | |
Eduardo Tola
Rep Power: 10 |
September 16, 2015, 11:18 |
Andrew Kokemoor
Bruno's answer is probably easier to implement, but I'll put out an alternative option, just in case.
Under Calculation Activities, you can run some scheme code every X iterations or timesteps. If you have an on-demand UDF, you can call it with Code:
(%udf-on-demand "udfname::libudf") |
September 14, 2017, 12:48 |
#9 | |
Astio Lamar
I have the same issue and want to use this method to call the UDF every certain iteration. If I understand correctly, this code needs to be compiled rather than interpret. However, when I interpret, I got "Parse error" In another try, I have successfully compiled the UDF, but cannot load it due to the following error: Code:
Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64). \n\nThe system cannot find the file specified. \n\nC:\...\libudf\win64\3ddp_host\libudf.dll Error Object: #f Thanks. |
compiled, dpm, fluent, iteration, udf |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 21:33 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
