September 26, 2015, 01:24 |
Send file to Cluster(Help Please)
Mohammad
Rep Power: 11 |
Hi my friends
I want to send a file from fluent to linux Cluster and I never do this before. I so Confused, what should I do in fluent??? which file I should get from fluent and how? Please help me, I should learn it. Best regards |
September 28, 2015, 07:45 |
Rick
Rep Power: 26 |
this has nothing or little to do with fluent itself. You need to have files on the head machine of the cluster: how you send the files is up to you: if you have access to the cluster you can manually copy paste files, if the cluster has ftp you can open a shell and send files through ftp, or if you have rights you can access the cluster via remote login, send files to a cloud or email and download on the head machine. Files to be transferred are cas, (dat), udf (if you use), profiles (if you use). Once you have the files on the head machine you can load them in fluent, compile udf (if you use) and proceed with simulation.
Google is your friend and the same for the search button! |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
