2D vertical laminar flow - Error: Divergence detected in AMG solver: x-momentum |
April 29, 2016, 04:56 |
#21 |
enass
Rep Power: 11 |
What do you mean by moving geometry in the first quadrant?
April 29, 2016, 05:08 |
#22 | |
VT
Rep Power: 10 |
A(4,4); B(5,4); C(4,14); D(5,14). And, because of the radius is 0.5, now you can choose any edge to be an axis. Now the amg errors should be gone. |
April 29, 2016, 05:18 |
#23 |
enass
Rep Power: 11 |
Now when you did so you obtained different results?
April 29, 2016, 05:20 |
#24 |
VT
Rep Power: 10 |
April 29, 2016, 05:55 |
#25 |
enass
Rep Power: 11 |
But when i simulated the horizontal case just as I described above i obtained same results as tutorial.. Why when i do vertical case in xy positive quadrant it gave same results as horizontal??
April 29, 2016, 06:00 |
#26 |
VT
Rep Power: 10 |
I don't follow you... You had sim a vertical pipe, right? And you had an error, the amg error, is it right? To solve that error try to move geometry how i have already written, and see if you solve the error! Run the sim, and please, tell me your results, maybe am i in error during setup.
April 29, 2016, 06:03 |
#27 |
enass
Rep Power: 11 |
I received no error when i placed pipe lying horiZontal and enable gravity in -x
April 29, 2016, 06:55 |
#28 |
VT
Rep Power: 10 |
April 29, 2016, 07:30 |
#29 |
enass
Rep Power: 11 |
refer to your inbox please
April 29, 2016, 09:03 |
#30 | |
Lucky
Rep Power: 66 |
For developing flows it is also similar, though not exactly. In the Blasius-type boundary layer equations the influence of pressure is reduced to a constant pressure gradient (and if the gradient is a constant, then it also acts like a constant body force). So local pressure distribution would be a higher order effect. |
April 29, 2016, 09:16 |
#31 | |
enass
Rep Power: 11 |
April 29, 2016, 09:17 |
#32 | |
VT
Rep Power: 10 |
Another question, why if i place a vertical pipe, with edges in the first quadrant, but far away from the origin of the axes, i had a solution different from the horizontal case? |
April 29, 2016, 09:59 |
#33 |
enass
Rep Power: 11 |
I totally agree with LuckyTran cause I performed all theoretical calculations for both geometry the velocity profile, pressure drop n skin friction coefficient should all be same. I did both cases as plannar and results emphasis that. as i said earlier my problem is in simulating axisymmetric vertical pipe.
May 3, 2016, 18:04 |
#34 |
enass
Rep Power: 11 |
LuckyTran can you advise me here please. I made horizontal pipe 2D with centerline being on x axis. I then enabled gravity in -x direction. The inlet boundary condition is specified to inlet with radial velocity component. I think now fluent understands it as vertical upward flow. I then run case and I received reversed flow in solution panel and flow is not developed?? Any suggestions??
divergence detected in AMG solver: momentum | sudhakar | FLUENT | 41 | January 23, 2024 03:56 |
Divergence detected in AMG solver | Mina_Mbg | FLUENT | 5 | May 9, 2018 04:04 |
divergence detected in amg solver temperature increasing relaxation sweeps | Kashif Rashid | FLUENT | 3 | May 3, 2014 06:23 |
Divergence detected in AMG solver : epsilion | maheshbabu | FLUENT | 0 | April 4, 2014 05:54 |
reverse flow and divergence in AMG solver | MASOUD | FLUENT | 2 | April 2, 2010 08:48 |
