November 19, 2015, 05:36 |
Problem running fluent with udf on batch
Tobi B.
I am trying to run fluent 16.1 in batch mode using Linux openSUSE and I am using the following command: fluent161 3ddp -g -i fluent.jou My journal (fluent.jou) contains: file/read-case-data Test.cas solve/initialize initialize solve/iterate 20 file/write-case-data Test.dat exit yes When I`m trying to run fluent this way, everything is fine. Now I want to use a UDF file. When I try to run fluent with the GUI everything is fine. I can compile and hook my UDF and Fluent calculates the solution. But when I try the same case (with the compiled and loaded UDF) in batch mode, Fluent doesn`t calculate the solution. The following message appears: /usr/ansys_inc/v161/fluent/fluent16.1.0/lnamd64/3ddp/fluent.16.1.0: symbol lookup error: libudf/lnamd64/3ddp/libudf.so: undefined symbol: F_PART Does anyone have a solution for this? Thanks |
November 25, 2015, 16:23 |
Jim
Rep Power: 11 |
hi tobi
have you tried including a command after the one that opens the case & data file, that will load the UDF library ? |
December 17, 2015, 11:27 |
#3 | |
Tobi B.
Hi, i `m sorry for my late answer! But now I have the solution to my problem. The problem was that I run fluent in parallel,when I was trying out the UDF. But on Batch Mode I run fluent serial. But there is a difference in the wording of the UDF library in parallel or serial operation. In parallel, there are two folders in the path libudf/lnamd64/: 3ddp_host and 3ddp_node but in serial there is just one folder: 3ddp. Therfore fluent could not find the folder 3ddp in serial use in batch mode. In parallel, it worked then perfectly. Greetings |
April 14, 2016, 13:54 |
details
#4 | |
sherzad
Rep Power: 10 |
please can you give us more details |
batch mode, fluent - udf, problem |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
Fluent UDF c source file problem (Linux) | jayilosa | Fluent UDF and Scheme Programming | 1 | November 21, 2011 08:25 |
fluent udf problem for 3d case | srsahu | Fluent UDF and Scheme Programming | 0 | July 28, 2009 07:25 |
A Loop problem when running UDF in the batch mode | Jun Geng | FLUENT | 3 | July 16, 2008 08:34 |
