Turbulence
Old   November 25, 2015, 15:11
Default Turbulence
dale154 is on a distinguished road
Hi, i have tested two turbulence models and just have a question about differences in solution.
I am modelling flow through a 2D compressor cascade.
Firstly i use k-omega turbulence and get a converging solution, however pressure values seem quite high.
However for some profiles i can't get a converging solution so i try SST-Transition and get a converging solution.
From this Pressure values seem more reasonable and velocity values are similar to that of the k-omega results.
I was wondering if anyone had any ideas on the differences observed between the two models?
(Note. 2D steady model, compressible, transonic flow with periodic boundaries).
I hope this is clear.
Thanks,
Dale.
dale154 is offline   Reply With Quote
Old   November 25, 2015, 16:01
Jim
CFDYourself is on a distinguished road
hi dale,
The k-w model and the SST model are similar. the SST model blends the k-w model at the wall, and uses k-e model in the bulk. this plays to the strengths of the two models; k-w allows the flow to solve the boundary layer without relying on a wall function, while k-e model is more stable than k-w in the bulk.
CFDYourself is offline   Reply With Quote
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Turbulence length scale Leonpolou FLUENT 2 January 23, 2013 07:26
How to implement turbulence in one Solver??? vahid.najafi OpenFOAM Programming & Development 0 July 29, 2012 05:46
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
How's going on with Turbulence Research? Daniel Main CFD Forum 1 June 20, 2008 23:44
