Modelling phase change materials in a container
Old   November 29, 2015, 16:43
Default Modelling phase change materials in a container
kez
Kieron
kez is on a distinguished road
I am modelling phase change materials in a container, the container consists of three regions, cold, pcm and hot. The heat from the hot side will melt the pcm and release the stored heat from the pcm to the cold region. Therefore simulating the heat flux from hot to cold with the use of the pcm as a storage unit.
I have used "fill cavity" to model the regions
The problem:
I am not quite sure how to exactly model the problem
I am not sure how to correctly setup the regions so fluent understand which regions contain which fluids, and
how to setup the monitors for heat flux.
I have attempted the problem before asking, however I dont feel I am setting this up correctly at all. The container is shown, any help would be appreciated for modelling and setting up.
kez is offline   Reply With Quote
Old   December 3, 2015, 09:56
kez
Kieron
bump, still need help with this :/
Old   March 24, 2016, 09:26
wan asyraf wan man
WanAsyraf is on a distinguished road
i am facing the same problem now, have you solve it? if yes, do you mind to share it. thanks
WanAsyraf is offline   Reply With Quote
which Model to be used for phase change? dinesh FLUENT 0 July 10, 2013 05:07
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 06:37
Solid/liquid phase change using large viscosity gregor.vidmar153 OpenFOAM Running, Solving & CFD 3 June 10, 2010 06:31
Modelling Phase Change using software.... ting Main CFD Forum 0 November 21, 2003 00:38
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
