error in parallel processing
Old   July 8, 2015, 10:23
Default error in parallel processing
karim
mkarim is on a distinguished road
i have project that boundary condition change with time(udf) and calculation in 2 processor machine and in parallel is good but in 4 processor machine have below error
please help me thank you
Node 2: Process 748: Received signal SIGSEGV.
unable to read the cmd header on the pmi context, Error = -1
Error posting readv, An existing connection was forcibly closed by the remote host.(10054)
The fl process could not be started.
received suspend command for a pmi context that doesn't exist: unmatched id = 3
mkarim is offline   Reply With Quote
Old   December 15, 2015, 00:13
abed
toghay is on a distinguished road
Hi mkarim,
Have you solved your problem? Actually I have the same problem as yours. If you find the solution, would you please tell me? Thanks.
toghaya@gmail.com
toghay is offline   Reply With Quote
error, parallel, signal sigsegv, udf
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
problem for parallel processing minaret OpenFOAM Running, Solving & CFD 14 January 19, 2015 23:41
OF Parallel Processing with Core i7 - How to Handle Hyperthreading dancfd OpenFOAM Running, Solving & CFD 5 March 5, 2012 21:43
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
About parallel processing in Linux tuks CFX 10 August 8, 2005 08:22
