How to calculate the torque in transient Ansys Fluent
Old   January 25, 2016, 12:34
Default How to calculate the torque in transient Ansys Fluent
Ronald Thompson
dynamic is on a distinguished road
I am trying to determine the optimum angle of attack at each position for a VAWT turbine for a certain airfoil, I want to export the torque at each time step of my transient analysis for the entire rotation. I am using fluent 14.5
A similar question was asked in the CFX forum where someone commented "I would export the torque versus time history To get the full time history, make a monitor point set to torque_x/y/z()@location and then export this point in the solver manager" it was recommended I repost here.
I tried creating a monitoring point and setting the expression as stated above in the calculation activities in fluent but when I run it is says invalid command
what am I doing wrong? have you to use a different approach in fluent than CFX?
Thanks
dynamic is offline   Reply With Quote
Old   January 26, 2016, 10:44
Default How to calculate the torque in Ansys Fluent
Radwanma
Radwanma is on a distinguished road
I have built a full wind turbine model but I have problem when I run the model in Fluent I have not got right Cm ( torque coefficient) values ??? Can someone give me a piece of information or any advice about that, please ?!
Thanks,
Radwanma is offline   Reply With Quote
Old   January 26, 2016, 12:28
Ronald Thompson
are you doing 2d/3d analysis?
make sure you have set your reference values correctly
Old   January 27, 2016, 05:10
Radwanma
HI Ronald,
Thanks for quick response. I have built a 3D model as shown below but Cm values still low !!!!!
cfx, fluent, monitor points, torque
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 00:49
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
Using FLUENT transient data in CFD-Post GJC075 FLUENT 0 November 25, 2013 09:56
Results are different for Ansys Fluent 14.0 and Fluent 6.3 syavash Fluent UDF and Scheme Programming 1 February 17, 2013 01:09
Transient FSI heat transfer using FLUENT and ANSYS kevpw FLUENT 0 March 26, 2010 16:04
