January 29, 2016, 10:19 |
2D phase change modelling
Kieron
Rep Power: 11 |
I am currently in the process of setting up a 2D model to simulate the phase change (solid-liquid) of polyethylene glycol. I have created a surface 66x180, using named selections for the input, output and symmetry. The aim of this project is to show the heat transfer from the input to the output using phase change. I have tried numerous times to set this up but every time I run the calculation the solution converges within 2/3 iterations with a fairly linear static temperature from input to output. I feel like I am doing something, quite obviously, wrong however I can't find where. Would anyone be able to take a look and point me in the right direction? https://www.dropbox.com/s/5fe1ez5otv...Model.zip?dl=0 Regards kez. |
Phase Change Modeling | Amar Kad | Fluent Multiphase | 8 | June 24, 2019 05:47 |
Phase change | mohan.dey4 | CFD Freelancers | 1 | January 3, 2016 09:47 |
Simulation of Phase change material (PCM) and nanoparticles together | farah | Main CFD Forum | 0 | November 2, 2015 14:30 |
phase change with CFX | aximefu | CFX | 5 | March 28, 2012 03:38 |
Two phase flow with phase change | Ahmad Al-Zoubi | CFX | 1 | November 26, 2008 03:59 |
