Simulation of Convective Heat Transfer Question
Old   February 4, 2016, 13:55
Exclamation Simulation of Convective Heat Transfer Question
Sireetorn
sireetorn is on a distinguished road
I'm currently trying to simulate within ANSYS v16.1 within the workbench that involves Fluent (CFD).
The model that I'm trying to simulate is the heat transfer in a mini-channel, in order to gain a set of Nusselt number results for the following different prandtl numbers of 5.4 and 2.2 with a Reynold's number of 4000 - 10,000 based on laminar flow.
I found an example that was similar to my problem, shown in the link provided below. However the difference is that I am using liquid water (instead of air as shown in the link) and the channel is only heated from one side.
https://confluence.cornell.edu/displ...ady+Convection
I have based my simulation on the example shown in the link and I've changed the fluid state from air to liquid water and the program isn't allowing to get a set of results. It doesn't seem to carry the calculations out and collect results from the model.
I would appreciate it greatly for anyone who is able to give me a step in the right direction or recommend any book or a document that will be of great help.
Thank you very much.
sireetorn is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
New guy trying to solve his first simple Heat Transfer simulation. BhaluBear OpenFOAM 2 August 12, 2014 12:54
Simulating Heat Transfer Spookz CFX 4 November 19, 2012 16:52
Heat Transfer boundary conditions for engine coolant flow simulation rajuks Main CFD Forum 0 February 15, 2010 09:04
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
