March 11, 2016, 18:16 |
velocity inlet boundary condition
zxc
Rep Power: 11 |
Hi
Does fluent can detect negative velocity in velocity inlet boundary condition? It means that direction is variabe sometimes i need a reversed direction Thanks |
March 15, 2016, 01:23 |
Lucky
Rep Power: 66 |
You can specify an arbitrary direction vector for the velocity.
But Fluent does not do any "detection." The velocity is specified by you so I don't what you want Fluent to detect. |
March 15, 2016, 05:16 |
Nader Khattabi
Rep Power: 10 |
here I attached some images that explains how to set your velocity in a readable way for FLUENT.
Before going to FLUENT, you can: 1/ create named selections for your velocity inlet and outlet using DesignModeler or Ansys meshing (the images 1/2 show how to do that using Ansys meshing) . 2/open Fluent and import your mesh (the one that you already created named selection in ) 3/go to Boundary conditions, you notice that FLUENT recognize the velocity inlet as shown in image 3. Edit your velocity inlet as shown (either using magnitude and directions or components of velocity as shown in images 4 and 5 ) . |
March 15, 2016, 13:04 |
zxc
Rep Power: 11 |
Thanks but there is a problem with this:
The negative direction is available just for one coordinate for example just x direction or just y direction could be negative and other must be possitive. I mean the condition that both of them be negative how can i do this? |
March 15, 2016, 14:35 |
Nader Khattabi
Rep Power: 10 |
It depends on the named selections you make, if you have two directions of velocity select two external faces (as you saw above) and set two surfaces as velocity-inlet1 and velocity-inlet2 then Fluent will recognize them both , and you can set each one of them on a negative direction(like -55,0,0 inlet1 and 0,-55,0 inlet2 for components of velocity) it will be what you are looking for since your domain is homogenous and contain the same fluid with the same properties
UDF: Change boundary condition. Velocity inlet to pressure inlet at time "t" | jpina | FLUENT | 10 | April 11, 2015 14:19 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
velocity profile inlet boundary condition question | Lcw | FLUENT | 3 | August 3, 2012 05:53 |
How to set up the inlet boundary condition for a low pressure case? | beastieboys6 | FLUENT | 3 | April 10, 2012 22:46 |
Velocity inlet boundary condition for porous medium | Chander | CFX | 3 | March 11, 2012 21:18 |
