Is it possible to patch an initial profile to a cell zone? |
March 18, 2016, 10:21 |
François Grégoire
Rep Power: 17 |
Here is my situation:
- I do a first run of a transient model. - After the 1st run, I want to patch the final temperature of Zone 1 as the initial temperature of Zone 2 for the 2nd run. Is it possible to do that? The mesh is identical is both zones. Last edited by macfly; March 18, 2016 at 16:16. |
March 18, 2016, 10:36 |
Lucky
Rep Power: 66 |
Create a cell-zone profile or write the solution into an interpolate file. Then edit the x,y,z coordinates to match the cell zone 2 (using matlab or something). Then import and apply to zone 2.
Or translate the mesh & solution, then write the profile/interpolate file for zone 1, and then apply it to zone 2 on the original un-translated mesh. Technically the mesh isn't identical because the x,y,z coordinates of each face are different, even if they are topologically equivalent. |
March 18, 2016, 11:36 |
François Grégoire
Rep Power: 17 |
I tried the translate mesh method. It works fine for boundaries where the profile can be selected in the drop-down list of a boundary dialog box. My problem is for the cell zones, just clicking 'apply' for e.g. int_interior1 in the profiles dialog box does nothing, the profile temperature is not applied. After applying the cell zone profile, I iterate a very small time step, e.g. 1e-6 second, just to see if the temperature was updated when applying the profile, but no, it was not applied.
March 18, 2016, 21:57 |
François Grégoire
Rep Power: 17 |
Found a workaround. It works if I activate 'Fixed values' in the cell zone dialog box, select the zone profile, run a dummy simulation so that the profile is applied, then I can start a new transient run without initializing.
Yet another cumbersome workaround to achieve a simple task in Fluent. |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
