April 4, 2016, 02:36 |
Problem in 2D dynamic meshing
I am using mapped quadrilateral mesh. dynamic meshing is enabled to adjust the mesh according to the deformation produced at the boundary. I am using spring based smoothing with spring constant factor = 1, node under relaxation=1 and re-meshing methods with some appropriate minimum length scale and maximum length scale values. I have also set the interior as deforming. The problem is that I don't see the interior deforming
also new cells are produced near the deforming boundary but there exist a gap where new cells are not produced no matter how much I decrease the maximum length scale value. this can be seen in the attached image. kindly provide some useful suggestions |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[ICEM] Meshing Problem ? | Leifheit | ANSYS Meshing & Geometry | 3 | December 4, 2014 18:09 |
UDF for dynamic meshing? | prasaddeole | FLUENT | 2 | October 6, 2014 11:55 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Dynamic meshing | Manoj Kumar | FLUENT | 3 | June 27, 2010 19:26 |
