April 6, 2016, 22:31 |
y+ problem in k-omega sst model
#1 | |
志新高(Zhixin Gao)
Rep Power: 11 |
Hi all,
I'been modeling using k-omega sst model. But I have some questions about the y+. In help document it says that y+<1, but there will be y+<0.02 in some places when I make sure the max y+<1, is it right? Quote:
Thanks. |
April 7, 2016, 05:01 |
#2 | |
ANSYS Fluent Theory Guide chapter 4.16. Near-Wall Treatments for Wall-Bounded Turbulent Flows (page 117 in the V17 version).
P.S. Don't worry about the y+ of 0.02.. it's just important that it's less than 1, not equal to 1.
If you're in need of some free quality CFD video tutorials - check out SiriusCFD @ YouTube |
April 7, 2016, 07:10 |
志新高(Zhixin Gao)
Rep Power: 11 |
Dear scipy,
I do what you quote but find the turbulent viscosity value seems to be smaller near wall compared to the core zone. By the way, My model is elbow. Best. |
April 7, 2016, 07:34 |
志新高(Zhixin Gao)
Rep Power: 11 |
I may find the reason http://www.computationalfluiddynamic...oundary-layer/
I use structure mesh, and the turbulent viscosity near wall is small and increase ,here is the contour. |
April 7, 2016, 15:06 |
You might consider a more appropriate cut plane location and displaying only the local min/max values. You could try and investigate a case of a simple straight pipe (no elbow) first, try to get a fully developed velocity profile and check if the boundary layer is captured appropriately. This is what I usually do (some simple proof of concept case just to check the physics and then move on to the actual problem).
April 7, 2016, 16:54 |
Lucky
Rep Power: 66 |
Turbulent viscosity is small directly adjacent to the wall where viscous effects dominate. Turbulent viscosity then increases rapidly, reaching a maximum, and then decreases again as your approach the edge of the boundary layer.
From either your results or a good initial guess, you need to infer the boundary layer thickness and then try to pack 40 cells in there. While this is just a guideline, take the instructions literally. Determine the boundary layer thickness, and the pack 40 cells in there. A lot of people get confused with these guidelines because they try to second guess what the guidelines are. They are simply just take. Find the boundary layer thickness, make sure there are 40 cells. |
April 10, 2016, 21:40 |
志新高(Zhixin Gao)
Rep Power: 11 |
Thanks, I'll try.
April 10, 2016, 21:42 |
志新高(Zhixin Gao)
Rep Power: 11 |
Thanks scipy. I'll do it again
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
turn off wall functions in Transition SST model? | johnp | FLUENT | 11 | May 26, 2020 13:57 |
K - epsilon VS SST turbulence model | Maicol | Main CFD Forum | 0 | November 30, 2012 16:25 |
convergence problem of the SST and RNG k-e model for mixing tank | ziyan7 | FLUENT | 0 | March 8, 2011 06:13 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 22:04 |
