Assist in a Fluent model
Old   May 25, 2016, 11:20
Post Assist in a Fluent model
Viktor
Je5u5 is on a distinguished road
Hello.
Im trying to build a 2D model of a tank filled with water, inside this tank there is a wall that is moving and creating waves, after this i want to track the particle trajectories to asses the best condition for particle grouping.
i made the wall inside the tank movie using a udf, but now i see its movement does not effect the "water" in the wave and thus not creating any velocity changes.
how can i make the wall movement affect the interior water using fluent.
Thank you.
Viktor
I attach my UDF for wall movement and a picture of the tank with the wall
#include "udf.h"
#define PI 3.14
DEFINE_CG_MOTION(movingwall,dt,vel,omega,time,dtim e)
Thread *t;
face_t f;
t=DT_THREAD(dt);
begin_f_loop(f,t)
vel[1]=0.05*sin(2*PI*time);
end_f_loop(f,t)
Je5u5 is offline   Reply With Quote
Old   May 29, 2016, 04:32
Viktor
Any Help?
or direction on witch model should i use?
Old   May 31, 2016, 10:51
Bhargav Bharathan
bhargavbharathan is on a distinguished road
I suggest trying out "dynamic mesh"
Check out this tutorial:
http://cae-club.ru/sites/default/fil...alling-box.pdf
You can find the associated files on the ANSYS portal.
-BB
bhargavbharathan is offline   Reply With Quote
Seeking Macroscopic Particle Model in Fluent bzhang7 FLUENT 3 June 25, 2022 17:54
Fluent :- turbulence Model prince_pahariaa FLUENT 9 May 20, 2016 03:41
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Fluent 12 k-w SST turbulence model DarrenC FLUENT 0 December 13, 2009 08:33
