Nose cone simulation
Old   February 28, 2017, 07:25
Default Nose cone simulation
Digvijay
digvijaypatil is on a distinguished road
i am doing nose cone analysis in fluent for temperature distribution on cone surface. After plotting the temperature contours it is observed that temperature from nose cone started increasing towards tail i am not sure it is correct or not. Can anyone one suggest me?
digvijaypatil is offline   Reply With Quote
Old   March 1, 2017, 04:51
Ruben
Rubblevg is on a distinguished road
Hi!
Although I am not an expert in this area, it would make more sense to me if the temperature is maximal at the tip of the cone, because the stagnation point of the flow is there. The temperature at the tip should be the stagnation temperature, which is as far as I know the highest temperature in such a system.
I hope this helps
Rubblevg is offline   Reply With Quote
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 15:06
Simulation of high pressure diesel injector - all phases compressible with cavitation fivos CFX 4 July 30, 2015 06:48
[ICEM] Problem with meshing around the blunt nose of a 3D cone shape D-willism ANSYS Meshing & Geometry 0 April 4, 2013 00:24
DPM: Cone and Solid Cone injection - what's the difference? JaC FLUENT 0 January 5, 2010 09:20
Hollow Cone Injection Problem JaC FLUENT 1 December 3, 2009 03:03
