droplet impact on a dry surface.... VOF again |
August 26, 2011, 19:20 |
Rep Power: 15 |
Hi. All,
I know there are some topics related to this droplet impact on a dry surface using VOF. But I still get lost. My question is how to setup the boundary conditions. In more detail, for a positive to the right and up respectively coordinate, I create a 2D rectangular face domain, 10mm (L) x 5mm (W), where a 2mm water droplet is located in the center. Both faces are using 0.1 interval size of mesh. I set the the four boundary as walls, also set the droplet as a velocity inlet. The multiphase (VOF) was used. Gravity is point to -Y. After setting a velocity (Vy = -1 m/s) for the droplet in Fluent and proceed the calculation. The droplet just did not move at all. Can someone shade me some light? Do I miss something else? Thanks. |
June 27, 2016, 02:12 |
help
tawfiq
Rep Power: 12 |
Hi rogerspass
Did you recieved any answer on your query, I have almost the same problem, if you know how to simulate droplet impact on solid surfcae please help me. With best regards |
Inconstant Surface Tension on Interface in VOF | Atieh | FLUENT | 0 | February 9, 2007 02:37 |
VOF simulation free surface caused by gas inject | rensb | FLUENT | 4 | July 20, 2006 04:45 |
VOF and droplet impact | simone marras | CFX | 4 | July 13, 2006 05:54 |
Surface tension options for VOF models | chapelle | FLUENT | 4 | September 20, 2005 03:49 |
VOF and Droplet Formation | saang | Siemens | 1 | June 7, 2005 03:59 |
