July 12, 2016, 09:20 |
Two phase model - Boundary Cond.
Amet
Rep Power: 9 |
i'm new to cfd. I have a questions.
i must study 2 phase. (water and air) i didn't find free surface heights so i try face split and I divide the surfaces into 2 parts. However i didn't set boundary condition. When i set the water inlet to water liquid, air inlet become phase 1 itself. However i want to: Water inlet --> Phase 1 Air inlet --> phase 2 what will i do? thanks a lot |
July 14, 2016, 00:38 |
Dai Nhan Nguyen
You can define phases as you need in "Solution Setup->Phases". And you should name inlets like inlet 1, inlet 2... for good management of boundary. I think so.
Good luck. |
July 14, 2016, 01:40 |
Amet
Rep Power: 9 |
Thank you for your reply, friend. Unfortunately, i set the phase you say but if i set water inlet --> phase 1, air inlet become phase 1 by itself. If i set air inlet--->phase 2, water inlet become phase 2 by itself
July 14, 2016, 02:44 |
Dai Nhan Nguyen
According to what you said, If you turned on multiphase model, phase of each inlet depends on your phase order (which is the primary, which is the second) and factor in multiphase tab of boundary properties.
I hope my words can be helpful. More detailed photos, more clear resolution! Good luck. |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
