February 17, 2010, 13:06 |
3D centrifugal pump y+ ?
Rep Power: 16 |
Hi guys,
I try to mesh a 3D centrifugal pump! Using spalart-allmaras model y+ has to be 1 or greater than 30. I made a boundary layer near the blades fine in order to achieve the y+ = 1. Because of the huge number of cells i cant do the same for the other walls of the pump. That will affect the solution? Is there anything else that i have to care for using this model? Thanks |
April 30, 2010, 14:23 |
Rep Power: 17 |
The only way to know if the solution is affected is to demonstrate grid independence.
July 13, 2016, 14:14 |
Have a nice time!
Rep Power: 11 |
Is there a formula that is used to calculate the y+ for the pump simulations?
release of the ERCOFTAC centrifugal pump - Fourth OpenFOAM Workshop | olivier | OpenFOAM | 8 | October 29, 2018 07:49 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
centrifugal pump and centrifugal fan | Mangesh | Main CFD Forum | 3 | January 3, 2006 11:21 |
Centrifugal Pump Modeling | Mostafa | Main CFD Forum | 4 | May 9, 2001 12:07 |
stator-rotor interaction in the centrifugal pump | G.H.Lee | Main CFD Forum | 4 | May 25, 1999 07:33 |
