Interface between rotating and static zone
Old   July 28, 2016, 09:46
Default Interface between rotating and static zone
Dog92 is on a distinguished road
i have a problem regarding the interface between a rotating and static cell zone. Which settings do i need to adjust in Fluent to have a correct simulation? The case is pretty simple. I have a rotationally symmetric fluid zone. There is one inlet at the left side of the model and one outlet on the top of the model. The bottom part of the model rotates and the upper part doesnt. The result i got til now is that the velocity of the fluid at the border between the rotating and static part changes suddenly. I want it to change smoothly. The overall settings are correct. I just dont know the interface thing. Until now i simulated a completely rotating system.
Dog92 is offline   Reply With Quote
Old   July 28, 2016, 11:43
Zbynek is on a distinguished road
Can you post a picture of your result? There can be a few reasons of your problem. One is that you define velocities in a zone using wrong type (absolute vs. relative). Another reason can be bad mesh at the interface and therefore poor interpolation there. Or, if the discontinuity is not too large, it can be simply because of the way how Fluent postprocess the results. I quote a Fluent Guide:
You may instead create zone surfaces for the interface zones. Data displayed on these surfaces will be "one-sided''. That is, nodes on the interface zones will "see'' only the cells on one side of the grid interface, and slight discontinuities may appear when you plot contour lines across the interface. Note also that, for non-planar interface shapes in 3D, you may see small gaps in your plots of filled contours. These discontinuities and gaps are only graphical in nature. The solution does not have these discontinuities or gaps.
Zbynek is offline   Reply With Quote
Old   July 28, 2016, 13:42
Well, i dont really know how to post a picture, because i dont have a URL for it. Thats why i drawed the situation simplified below. Actually you have to imagine the Model 90 degrees turned anticlockwise. the rotating part is at the bottom and the static part above. How do i get a smooth decrease of velocity like i described with 'fast...slow...slower...0' ?
. fast---------------slow ! slower ----------------0 -.
. ------- Zone 1 ---------! --------Zone2---------- -.
.------- rotating (300rpm) ! ------static (0rpm) ------.
..............................Border....................................
boundary, interface, rotation, static
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Problem with interface between rotating and static domain Math13570 CFX 3 March 4, 2016 20:05
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
