August 2, 2016, 10:44 |
How to monitor Drag around a porous cylinder
Rep Power: 11 |
Hello member,
I am simulating a flow around a porous cylinder. The interface between the cylinder and the other bodies is not a wall, but an interface, because the cylinder is not a solid, but a porous body. The problem is that it is not possible to monitor the Drag at the cylinder surface since its surface is an interface not a wall, and the drag can be monitored only on a wall. Have you got any suggestions? Thank you |
June 3, 2017, 23:11 |
sofina
Rep Power: 8 |
I also want to get drag force at the porous surface . Did you find a solution to it?
drag, porous body |
Flow around a porous cylinder | Ema40 | FLUENT | 2 | June 4, 2017 06:59 |
rotating porous media in a general flow | a_dores | FLUENT | 0 | October 31, 2010 04:50 |
species mass source in porous media ? | PK | FLUENT | 0 | February 16, 2007 11:12 |
Porous Cylinder in a flow | PK | FLUENT | 1 | January 31, 2007 08:51 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
