Inviscid flow- Water hammer
Old   August 3, 2016, 14:46
Default Inviscid flow- Water hammer
Nader Khattabi
bboynido is on a distinguished road
I am currently trying to simulate the water hammer phenomenon for an inviscid flow with Fluent.
To do so, I have used a power point presentation provided below along with the numerical results for this case. I started with initial BC: pressure inlet , and mass flow rate outlet-open. after the convergence, i changed the BC for the outlet in order to create a closed valve (as shown below) and then i run the calculations again.
Unfortunately, the simulation does not seem to be valid compared to numerical results.
the pressure variation chart (provided below) that i found, shows a pressure drop which is not logical, as there should be no pressure drop if we are using an inviscid flow.
Does anyone have an idea of what could be the problem !
Thanks
bboynido is offline   Reply With Quote
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Outlet BC for subcritical open channel water flow Ema40 Fluent Multiphase 0 April 18, 2015 04:57
flow analysis of a submerged water turbine in Ansys 13 Anwerizer CFX 4 September 17, 2014 08:54
SSIIM 2, vertical elevation of the water surface, transient water flow parameters Mummputz Main CFD Forum 6 November 18, 2012 13:39
pressure distribution in water flow, differences in icoFoam and COMSOL deniggo OpenFOAM Running, Solving & CFD 14 September 30, 2010 03:48
