September 15, 2016, 19:19 |
UDS advective flux term divergence free
Yifei
Rep Power: 10 |
Hi folks,
I am currently modeling the electro-hydrodynamics equation using UDS. Considering that the UDF guide says "advective flux field that is supplied by your UDF should be divergence-free", I am wondering if the "advective flux field" here means the vector field of psi (which has a unit of velocity) or the product of psi and phi(uds). Since the electric field here is certainly not conserved due to the space charge effect but the current density is a conserved value for a steady-state solution, I am not sure if it is ok to type in the psi as "mobility * electric field and phi(uds) representing the charge density". Thank you for your help! |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
How can I avoid Divergence when simulating a boiling flux in FLUENT | P_VS | Fluent Multiphase | 0 | July 14, 2016 08:59 |
new divergence term in alpha1Eqn in inter Foam | danny123 | OpenFOAM Running, Solving & CFD | 1 | April 22, 2015 12:28 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
help:spectral methods & divergence free functionsn | D. Puigjaner | Main CFD Forum | 1 | August 28, 2000 10:06 |
