Boundary condition that is open to atmosphere in control volume |
December 4, 2016, 11:55 |
Onur Özcan
Rep Power: 12 |
what should be boundary condition that is open to atmosphere in control volume?
Pressure outlet or symmetry, That is why I ask, I have seen a case made as symmetry. |
December 4, 2016, 13:21 |
SinaJ
Rep Power: 16 |
symmetry as outlet?! I would say, maybe in those cases they used it as periodic boundary.
December 4, 2016, 13:27 |
#3 | |
Onur Özcan
Rep Power: 12 |
Periodic boundary is recurrent model ? the thing I have asked is what boundary condition is defined in those enclosures,control volume ? Kind Regards, |
December 5, 2016, 00:56 |
Rep Power: 18 |
Symmetry BC means: d(phi)/dn = 0, Un = 0, where phi - any variable, Un - normal velocity. Obviously there cannot be fluid flow through symmetry.
December 5, 2016, 01:06 |
Onur Özcan
Rep Power: 12 |
Model is attached. As you can see,outlet is very near to solid one. (that is my thought, maybe it is wrong approximation). How does boundaries in model be near to interest ? and what kind of boundary condition should be define it in model boundary ? all boundaries are imaginary. Because the model is control volume
December 5, 2016, 01:18 |
#6 | |
Rep Power: 18 |
December 5, 2016, 01:53 |
#7 | |
Onur Özcan
Rep Power: 12 |
So, as for model that I have defined , air (cooling air) is to define all imaginary boundaries (control volume). I take into condesiration on a solid material being heated via heat transfer and cooled by air.Which direction does the model be extended ? Actually I could not take into consideration air flow behaviour following cooling the material. I could say that I pay no attention how swirls or eddies are damped in symmetry boundary condition |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
